Why are there no vertival scroll bars in Navision Financial’s Forms? It is very confusing at times. You won’t know where you are, and are there any more records left on the top or bottom. The funny thing is, vertical scroll bars exist in reports…
The reason for this is speed. When a vertical scrollbar is used, it is neccessary (sp?) to calculate (and recalculate) at what (relative) position you are in the current table. To do this you need to count the number of records in your current view, and the number of records above (or below) your current record. This wouldn’t be much of a problem if it weren’t for the filters you can set on any field in the table. So it faster to not have vertical scrollbars in those windows. You’ll get used to them. Dennis van Es PerCom: Research & Development BV The Netherlands
