Need help in modifying report. In Microsoft Dynamics NAV Classic field menu., there is a No. Printed., I put it in report., but it’s not updating in some reports. it only updates in posted reports, PO and SO. I just did the same thing.,
Can you explain what did you do and where did you do?
What I did is
Open Microsoft Dynamics NAV Classic
Under Financial Management > I open the Payables > Credit Memo
CTRL+F2 > from field menu > i got the field No. Printed
I put it in form designer under general tab
ESC > compiled > then i went to the section designer
I put the No. printed > complied.
but when I do test printing, it’s not updating.
The Code executing in other reports is not availabel in Test Reports…
Add this code in Test report and try
IF NOT CurrReport.PREVIEW THEN
PurchCrMemoCountPrinted.RUN(“Purch. Cr. Memo Hdr.”);
it’s not indicated in global. what datatype is this? PurchCrMemoCountPrinted
Codeunit - 320
Solved - THANKS MOHANA!
Welcome
