No Cost Rollup is found Error !!!
I’ve created an item and when I tried to create purchase order(Receipt slip) for the particular Item It throws me an below error.
Can anyone help me out in this how to fix this error.
The image is not visible.
Sorry Adam,
Here I’ve attach
ed the error message.
Item PenBody is a standard costed item that you have not setup correctly. So you need to set your costing version fallback or go to the item and set the price (this will open the costing version, you define the cost price for the dimensions and then press the activate button).
Thank you Adam.
What did you do to correct this transaction? We are having the same issue, except that there is a cost for this item.
In the item costing version just activate the item cost for the particular item… Jim. It’ll work.
