NEW FIELD NEEDED
hi all,
I would like to add a new email field , simple because we have customers with alternative email addresses.
I have made a clone of the original email field, however this has also copied all the current email addresses into the new field.
anyone have any Ideas?
Saf
I guess that you had copy in form. You must add the field in table and them add it in form
Probably a good solution. But if you by chance need a third field? And a fourth?
Take a look at standard Contacts (“Salges & Marketing”/Marketing/Contacts). There you may define your Customer as a Contact and make a link; and you may define “Related Contacts” (e.g. persons) to the Contact. Each [Related] Contact has its own E-mail-field.
hi all,
Saf
I guess your clone was produced when designing the form?
You need to add the field to the table with the same properties as the email field and then bring it forward on the form.
Cloning a field on a form just gets it to show the same data as it is a view on the same field in the table.
Duplicate post
http://dynamicsuser.net/forums/thread/88590.aspx
Merged. [;)]
