New Dimension Value Code
Does anyone know what the following field is used for: New Dimension Value Code in the table 357: Journal Line Dimension
“New Dimension Value Code” i used in “Item Reclass. Journal”.
Thanks. But can you give me an example when this is used?
When you will change dimension values on item ledger entries you can use “New Dimension Value Code”.
Thanks Bjarne. It’s clear to me now.
