new CommaIO returns null
Hello,
I have a static method to write a txt file in a specific directory, but this method seems not working; new commaIO returns always null. The filename is correct and the directory is authorized for writing (I tried to export a project there without any problem).
Any Idea? thx
server static void writeFile(str _filename, container _data)
CommaIo file;
int n;
FileIoPermission perm;
perm = new FileIoPermission(_filename, #io_append);
perm.assert();
file = new CommaIo(_filename, #io_append);
if(!file || file.status() != IO_Status::Ok)
throw error(strfmt(’@SYS75767’, _filename));
for (n=1; n <= conLen(_data); n++)
file.writeExp(conPeek(_data,n));
CodeAccessPermission::revertAssert();
… this method is called from a runbasebatch class
if put in a job works without problem…
found by myself, seems the method should be client
