I have a new customized form in which i created a button. i want insert a new line in that form whenever i clicked on that button.
Pls. help me
Thanks in Advance.
Pls. help me
Thanks in Advance.
right click in New Button → overide method() → clicked → after you can code X++ in that if you want Insert new line then you use method insert() in table ( example: SalesTable. insert()). note: (don’t should delete “super();”)
Hi taukeer,
Use button type - Commandbutton and set command property “New”.
Thanks. Its working fine.
Thanks Its working fine.
In that case, please close the thread by marking the verified answer (“This helped me”).
