Yes, the old users can access. just the new users cannot. I have a feeling this is a user account issue. But don’t know where to check if it is in AD or in Microsoft Dynamic itself.
Yes but the new users can’t,it prompts “You do not have access to Microsoft Dynamics NAV. Verify that you have been set up as a valid user in Microsoft Dynamics NAV”
<?xml version="1.0" encoding="utf-8" ?>
<configuration>
<appSettings>
Name of the machine hosting the Microsoft Dynamics Nav Server to
be connected to.
<add key="Server" value="ServerName" />
The listening TCP port for the Microsoft Dynamics NAV Server.
This is part of the server's URL.
Valid range: 1-65535
<add key="ClientServicesPort" value="7046"/>
Name of the Microsoft Dynamics NAV Server instance to connect
to (for client).
<add key="ServerInstance" value="InstanceName" />
Id of the tenant to connect to (for client).
<add key="TenantId" value="" />
The security services used to protect the client/server data stream.
Valid options: EncryptAndSign, Sign, None
<add key="ClientServicesProtectionLevel" value="EncryptAndSign"/>
Collection of past servers that have been connected to. This setting
should not be edited by the user.
<add key="UrlHistory" value=""/>
Threshold for when to start compressing data sets to avoid that they
consume prohibitive amounts of memory.
<add key="ClientServicesCompressionThreshold" value="64"/>
Sets the default size of a chunk, in KB. Should be a value between 4 and 80.
<add key="ClientServicesChunkSize" value="28" />
Sets the interval between reliable session keep alive messages in seconds.
If the NAV Server sits behind a load balancer, set this value to approx. half of the load balancer's idle timeout.
<add key="ClientServicesKeepAliveInterval" value="120" />
The amount rows that will be handled when sending a number of records through xml to Word or Excel.
<add key="MaxNoOfXMLRecordsToSend" value="5000" />
Maximum image size (in bytes) allowed by validation.
<add key="MaxImageSize" value="26214400" />
The type of client credential used for authentication.
Possible values:
Windows - Windows authentication is used, and client will connect with "current user"
this user is expected to be the same and known to both server and client
This is the default mode and is typically used on a LAN with Active Directory
In this mode X.509 certificates are not used and options set below are ignored
Username - Windows authentication on the server. Client is expected to present username/password
indentifying a windows user known (created) on the server.
Typically the client will ask for these credentials and pass them to the server
Certificates are used to protect the passing of credentials.
This is typically used when only the server is part of an Active Directory, or
when the client is not trusted, e.g. connection over a WAN/Internet
NavUserPassword - Authentication is managed by the server but not based on windows users.
Client is expected to present username/password matching a user known to the server.
This mode is used in hosted environments e.g. Azure where the list of allowed users
are maintained by NAV and not based on windows users.
AccessControlService - Authentication for the Role-Tailored Client is handled by Windows Azure Access Control Service.
An ACS namespace needs to be set up before. Also the Identity Providers need to be set up
as well as the Relying Party representing the NAV Role-Tailored Client.
To support ACS, you need to specify the ACS WS Federated authentication endpoint in the ACSUri.
<add key="ClientServicesCredentialType" value="Windows" />
Specifies the sign-in page that Microsoft Dynamics NAV redirects to when configured for Single Sign-On.
For Azure AD (Office 365) authentication, the ACSUri setting has the following format:
https://login.windows.net/<AAD TENANT ID>/wsfed?wa=wsignin1.0%26wtrealm=<APP ID URI>%26wreply=<APP RETURN URL>
Where
"<AAD TENANT ID>" is the ID of the Azure AD tenant, for example "CRONUSInternationLtd.onmicrosoft.com". Use "common" if the application is configured as a multitenant Azure AD application.
"<APP ID URI>" is the ID that was assigned to the Microsoft Dynamics NAV application when it was registered in Azure AD, for example "https://localhost/".
"<APP RETURN URL>" is the reply URL that was assigned to the Microsoft Dynamics NAV application when it was registered in Azure AD, for example "https://localhost/".
For ACS authentication, the ACSUri setting is a top level partition of ACS that is used to create the ACS tokens, for example "https://CRONUSInternationalLtd.accesscontrol.windows.net/v2/wsfederation?wa=wsignin1.0%26wtrealm=https%3a%2f%2flocalhost%2f"
Remarks:
- Notice the difference between ACS "wsfederation" and Azure AD "wsfed" resource
- The query string parameter needs to be URI-encoded (use "%26" instead of "&").
<add key="ACSUri" value="" />
<!-- Settings for making sure we're connecting to an authenticated server, and that it's the server we want to connect to. -->
Specifies whether NTLM fallback is permitted when authentication of the server is not needed.
Authentication of the server is only possible with kerberos.
To require Kerberos authentication, set this value to false.
This setting is only relevant if ClientServicesCredentialType is Windows.
<add key="AllowNtlm" value="true" />
Specifies whether the service requires an SPN from Active Directory.
If true, the connection will only be made to a service with an SPN <ServerInstance>/<Server>:<ClientServicesPort>
If false, the connection will be attempted to a service with or without an SPN.
This setting is only used together with Kerberos authentication and ClientServicesCredentialType is Windows.
<add key="ServicePrincipalNameRequired" value="False" />
Indicate if you want to enforce validation of the certificate.
In a production environment this is strongly recommended. (Default is true)
When validation is enabled, the certificate needs to be trusted, not revoked and the CN name should
match the URL of your service.
When validation is disabled you can use a self-signed certificate with no revocation list and there
are no constraint on the CN name
<add key="ServicesCertificateValidationEnabled" value="true" />
One of the initial checks when a client authenticates a server is to compare the value of the Subject field
of the certificate to the Uniform Resource Identifier (URI) used to contact the service: the DNS of both must match.
For example, if the URI of the service is "net.tcp://NavServer.com:7046/DynamicsNav/Service." then the Subject field
of the certificate must also contain the value "NavServer.com".
Most commonly, the Subject is prefixed with "CN" (for common name), e.g., "CN = NavServer.com", but it can also just be "NavServer.com".
It is also possible for the Subject field to be blank, in which case the validation rules will be applied to the Subject Alternative Name field of the certificate.
The DnsIdentity configuration settings can be used to associate an endpoint with the specified Dns name.
<add key="DnsIdentity" value="" />
Name of the Microsoft Dynamics NAV Help Server to connect
to. The value of the "Server" setting is used as the default.
<add key="HelpServer" value="" />
The listening TCP port for the Microsoft Dynamics NAV Help Server.
<add key="HelpServerPort" value="49000" />
Alternative product name for the Microsoft Dynamics NAV client.
Refer to the license terms before changing the product name.
<add key="ProductName" value="" />
</appSettings>
</configuration>
Will compare, I will contact the users again sorry, I am an overseas support based in Philippines and the users are in Singapore. I will update you once I get the config file. Thank you.
Thanks I am sure there is something missing around client settings. if the users are setup in NAV correctly , then it must the client for new users. comparing with similar users will help.
it could be that yes. You need to check every thing to get to bottom of this. The best reference you have is the fact that this works for older user which means you can replicate what it has been done for older users. What you need to check
Users are created in NAV and all look good
Client settings match with other users.
check event viewers in new users PCs as well and see you get a clue.
New users have enough training to login in NAV and making sure that they are using right credentials.
