Need to print a blank check
We print our own checks in Navision using magnetic ink and stock paper. The question is - how to print a blank check with Bank routing number and accounting number ONLY?
If you are interested in a 3 part product, LaserNet overlay could solve your “problem”. You can read more at the top, under Solutions/Add on offered, or I could send you a ScreenCam, which gives you an impression how this works. Further more, we have US resellers which can help you if this has any interest.
quote:
You just need making a report based on the bank account table with an integer as loop for the number of checks and “copy” the design you’re having on your actual check’s report.
