I have added a Enum in purachase order header & added a button in Purch lines.
Now my Requirement is Depending on header enum value i want to disable the button in lines.
if the enum value is 0 the button should be diable. Other than 0 the button should be enable.
How can i achive this ?
where i am writing that code in table level methods or IN form -->method?
Hi Kranti,
i am unable to understand that method. Can u plz explain some more clear.
if i call the method in form level field modified method. Where i have to mention the button. Can u plz make it clear for me and where i have to add that method ?
HI Roshan,
Place a code in the Form – DataSource — Fields ---- [Enum Field] ---- modified() override it and place a logic as
if(TableName.Fieldname[enumfield)] == 0)
button.enabled(true) // make the button property autodeclaration to yes…
else
button.enabled(false)
Naresh Kolli
set the autodeclaration property of the button in line to “Yes”
write the following code in PurchTable:Active() in PurchTable form.
let us assume buttonName is BN
if(enumfld.value==0)
BN.enabled(false);
else
BN.enabled(true);
Hope this will help u…
Hi Naresh,
Plz test for if u do modify the enum field, then check buttons behaviour…
CommandButtonsVisibility is a flagsenum, so you can OR together all the buttons you want to show. …
____________
Kim
india payroll software
Hi PrasannaKumar,
I have checked u r code. it is also working fine for my scenario. But i found a small problem in that code. i.e when ever i change the value in the enum the button status should not be change until i click on lines.
It is better to use the name of the Enum Value (like Enum::Value) for better readability of your code.
and you can write this in single line - button.enabled(Table.EnumField == EnumField::value); only for this value the button will be enabled…
What you are looking for?
