Need to change the status wen i give ok button in dialog box.
I need to change the status of the Transaction, once the checkout button is clicked.
I created a dialog box on checkout button using clicked method as:
db = box::yesNo(“Do you really want to checkout”, dialogButton::Yes, “Checkout”);
if (db == dialogButton::Yes)
// select forupdate axt
info( “We chose Yes”);
else
if (db == dialogButton::No)
info( “We chose No”);
But I don’t know how to change the status of tat transaction, please help how to do tat.
Thanks in advance
Hi Sri,
Please find the code below :
// Find below example.Add the below piece of code.Assign value to your datasource.field.This will update the value
axt.TransactionStatus = “Closed”;
else
Its not working can you give me the code more specifically…
I tried like this:
axt.Transaction_Status=Transaction_Status::Check_Out;
axt.update();
It showing an infolog as can’t edit a record.
This is my code in button clicked() and the name and date in my table TestTable is getting updated to “Sindhu” and 09/15/2017
void clicked()
DialogButton db;
super();
TestTable.Name = “Sindhu”;
TestTable.RmaInvoiceDate = today();
else
Can you remove this line and try
axt.update();
Thanks, Sindhu:)
I done as:
AX_TransactionHeader.Transaction_Status=Transaction_Status::Check_Out;
info( “You have successfully subscribed all the books”);
else
info( “Transaction has been cancelled”);
