Hello: I’m in need of a programmer that can modify my data base. We are using 3.70 and need to add a check box to the sales order data base that can be checked either before or after is has been posted. John
Hi, I could not understand your point corrcetly. Are you looking for a programmer then please post this query to other section of this forum.
Hi, if you want to add check box in table.create a new field in table with data type as boolean.
You are in the wrong board ! Post to the “Jobs offered” forum !
