Romeo i think this a long process. This because i knw its about replacing ZUP Files but the issues is i forgot how to do it using the CMD Command of Dos.
The DOS-command for deleting it is DEL.
I don’t know how you can search for it by DOS…
But why do you want to do it in DOS at all?
No need to make things harder than they are…
Simply open an explorer, navigate to the location of the ZUP file, and delete it.
Or… use the search-facility in Windows.
BTW…
Are you sure your DB doesn’t open?
I might be that the Navgation pane is closed.
(Or if you are on version below 4.0, that the menu-form somehow has “landed” outside the visible area.)
I can’t see how the ZUP file can make the DB not open when you try to, by doing File → Database → open from within Navision.
The reason why i want to delete the Zup file using Dos command is coz there aare times when u can delete them using the windows normal delete command but fail to delete. Physicall they might be deleted but still yr Nav will still have the previous issues it had.
So the best way forward on this (If the windows Delete doesnt seem to work) is to use the Dos Del command.
When you open the .FDB databse, does navision open? If Navision is opening & not showing anything, it could be that you have not opened any company. You can open a Company by pressing F12 or click on File → Company → Open and select the company you want to open.
No its Not opening. I usually opens it by double clicking the .FDB File. But this time round when i do that the File jst doesn’t open. I keep on repeating but no success.
