Dear
I want to integrate Visual Basic with Navision 4.0 Database
I have created DSN & now trying the connection thru ODBC,
If someone have do it earlier then please help me out.
Ashish Bhardwah
Dear
Ashish Bhardwah
Try MBS Navision - ODBC Connection Workbench v1.00
Read NODBC-Doku
And my personal CheckList:
After this read something over standard ODBC in VB (.NET?) or ask a further question.
And if you realy want to “use VB in Navision” then check this video
http://laputa.sharpdevelop.net/content/binary/SharpDevelopForApplications.wmv
Hi Ashish,
I’ve do a test previously, and it’s working, but with vb 6.0
Do you try with VB or .NET ?
wich kind of information do you need ?
Luc
Your link is to a password protected video. I could not access it,
It’s an open video.
But try http://laputa.sharpdevelop.net/AnnouncingSharpDevelopForApplicationsSDA.aspx
Dear
Can you please suggest the way to do it with ver 6.0
thanks
Ashish
Ashish,
1°) You need to configure an ODBC driver to navision (DSN) (with or without givving the sql database or the path of the database if native database)
2°) in VB
and declare the vairable
Public dbs As DAO.Database
Set dbs = OpenDatabase("", False, False, “ODBC;DSN=Navision;uid=xxx;pwd=xxxx”)
place a List Box on a form and use this code
Sub ListTab()
Dim tbdf As TableDef
FrmDBViewer.cmbListeTables.Clear
FrmDBViewer.LstTables.Clear
For Each tbdf In dbs.TableDefs
FrmDBViewer.cmbListeTables.AddItem tbdf.Name
Next
End Sub
Place a DataGrid Control on the form and
Sub visualiser()
Dim rsTest As Recordset
On Error Resume Next
Set rsTest = dbs.OpenRecordset("SELECT ‘No.’,‘Name’ FROM " & FrmDBViewer.cmbListeTables.Text & “;”)
rsTest.MoveLast
MsgBox rsTest.RecordCount
Set FrmDBViewer.DtGrd1.DataSource = rsTest
FrmDBViewer.DtGrd1.Refresh
rsTest.MoveFirst
With rsTest
Do While Not .EOF
MsgBox "No. : " & rsTest.Fields(0).Value
.MoveNext
Loop
End With
rsTest.Close
Set rsTest = Nothing
End Sub
dbs.Close
Set dbs = Nothing
It’s a sample, I hope’s that help you.
Dear Hebus
Thanks for the reply
one more way I have tried with ADODC for that i have used its property & linked with the Navision ODBC Data Source Name & specify the Table in recordSource & then created a form where i have used the Text boxes linked with ADODC & Datafield property.
Also i have placed the datagrid & make it’s Datasource Property to ADODC.
It’s working fine.
I will also check your method.
Ashish
can anyone tell me, how to connect to Navision database version 3.56 through ASP pages? I set the DSN and wanted to run the following:
strDSN = “aaa”
strUser = “bbb”
strPwd = “ccc”
Set conn = Server.CreateObject(“ADODB.Connection”)
conn.open strDSN,strUser,strPwd
But it didn’t work. Has anyone experience in this? Thanks!
