Can someone recommend a server hardware configuration for a Navision Terminal Server. The server will be dedicated to Navision and will support 10 to 15 users. Thanks Dan
You could try this site: http://www.workthin.com/tshw.htm It belongs to one of the members and I’m sure he will probably also pop along for a comment or two when he finds this topic.
Thanks for the link
You have to thank Patrick Rouse, it’s his web site. Check out this topic, for example: http://www.mbsonline.org/forum/topic.asp?TOPIC_ID=9144
Glad you found it of use, but let me clarify something. Are you setting up a terminal server for 15 users to run the Navision Client against a database which is on another computer (hope so), or planning on running the DB and TS on the same box (hope not). Just checking. I’m not saying it’s not possible to run both on one machine, but TS is normally setup like a workstation, where no data is stored locally. Anyways, you probably knew this, but thought I’d throw it out there. If there are other things you’d like to see on this site, please don’t hesitate to contact me via email (on the site). The content that’s up there I’ve put up over the past month or two, basically by sifthing through all of the bookmarks & whitepapers that I’ve accumulated over the years. Happy weekend.
quote:
