Greetings I was wondering if anyone can assist me with this issue that I have. I need to create a table key based on 15 code40 fields, however the Navision database can only set a certain amount of bites for keys. Does anyone know how to extend the bite size limitation that Navision has set when create table keys?
You can’t. Are you sure you need 15 Code40 fields in one Table, let alone a Key based on all of them?
quote:
Wau! - what kind of data is that?
It Key is for a cube of data that is forecasted on. Very similiar to the Budget Forcaset Entry table, when it has a very large key setup for for the Naivsion matrix control box, which is used in the flowfilter field “Budget Amount” in the gl account table.
