Navision stopped working when I click on the Customers and some other errors
Dear All,
I am facing with some errors when I use NAVISION. The first time I see such errors. Please can you help me what is going on?
1.When I click on Customers (everywhere ,like Financial Management / Receivables / Customers), Navision has stop working. It is happening all the time, without exceptions.
And I have the same error when I click in the Vendors menu as well.
  1. I am not able to use the Excel Export function of NAV. When I try to send something to Excel, I always get the following error message:
  1. When I try to Preview a report, I always receive the following error message:
Please can you help me to understand what is going on with those errors? :frowning:
That is three different none linked errors…
Besides from the error messages, you do not provide much info and therefore it is difficult to help you. But here is a few suggestions to things you should start with
Errormessage 1:
Start the development environment and run the table 18 - Customer directly - If that is possible then there is something wrong with your Customer List page. If the Customer table does not run then what error do you get.
Run the page 22 - If that one does not run - then you should get an errormessage about why - Most likely because a field has been deleted on the table and not on the page.
In Development try to select functions, and build server objects.
Errormessage 2:
Is this a new message? A new user? all users?
The error message tells you what is wrong, the foldername is missing. Perhaps you do not have write permission to the folders on the computer?
Errormessage: 3
Printer Selection is mission. Does it work in Cronus International Company or in one of the other companies you might have?
