Navision Server Service Error.
Can somebody help me sort out this error which am getting when i try to start a navision server service.
Could not start the Microsoft Dynamics NAV Database Server service on Local Computer.
Error 1: Incorrect function.
Please assist what to do.
Have you changed the license file???
is it working fine before?
Error 1 is an operating system error. Typical cause is memory. How much memory (DB Cache) did you set the db service for? Try 850000. Provided you have that much free. if not, reduce that number.
I re-installed the navision server again and this time round allocated 850000 kb to cache. i have also made sure i have all the rights on the computer am using.
Now the service is taking too long to start and even to stop. when i try to restart it it gives error 1053.
Whats the solution to this?
Try these following solutions:
  1. Go to the services.msc then go the properties of the services you’ve installed. On the Log On tab, Log On as must be “Local System Account”.
  2. Try to check the port number you’ve used. It may be already used by other services.
  3. Double check the path of the services you’ve installed.
Hope this would help you.
