I am setting up a Navsion replicator but i am having issues running the scheduler. I can run all the specifications and the groups without the scheduler but if try running the command promp using “repnt g=scheduler” it returns an error telling me that the company name does not exist and that is the correct company name. Can someone help me on this please?
You check the company name both sides (from and to). What is the command sequence you have given? Can you tell me once? So, that i may be in a position to clarify some more.
reg.
sasidhar.
Yes i have check both from and to company name. I am able to run group specifications code or any of the specifications without have this company name error. From reason or the other replicator scheduler is seeing this company name as an error while the others are not.
