Navision Financials V2.01.A. C/ODBC
We use Navision Financials V2.01.A.
On Windows server 2003 terminal server I have installed the Nav client and C/ODBC driver V2.11.00.924 from the original installation CD
Logged on as administrator it’s working just fine when importing data to Excel, but when ordinary users are logged in they got this error when importing data to Excel
The operation system cannot gain access to the file ??? ???
Please check that the file type and attributes are correct.
If users are member of local administrator group it’s also work fine for them but that is not a solution I want to use. [:(]
I found a link to a solution of the problem, but as you know this site is down
http://www.navision.net/forum/topic.asp?TOPIC_ID=4929
Does any body know where I can reach this link or have a solution off my problem it would be appreciated
Regards Jesper
you can try:
http://www.mbsonline.org/forum/topic.asp?TOPIC_ID=4929
br
Josef Metz
Tanks for answer Josef
I have no access to the topic have to be logged in but have no user account on that site
If topic actual does exist and you or any one else for that matter have access pleas copy and pasta the topic answer here
Thanks in advanced
Jesper
Original question:
Hello,
I have the following problem:
I install Navision Financials V2.01.A. Then I install C/ODBC from the same CDROM (CODBC.DLL V2.11.00.924). The operating sytem is MS-Windows 2000 SP2 (german). I install this as administrator. Then I logoff and login as user. Now, when I try to make a C/ODBC request (with MS Query for example) I get the following error message:
Then I press the button and the following message comes up:
S0000 [Navision Software a/s][Navision Financials ODBC Driver]Base initialization failed
I only can press and the request cames back with no data.
(The six question marks in the first error box come in the same manner as I have posted it.)
I’ve tried a newer codbc.dll (2.11.02.1507 from 28.07.1999) but it doesn’t work too.
Rolf
First answer:
Make sure that the SYSTEM user has full access to C:\ folder. By default W2K/XP has SYSTEM access as part of the default EVERYONE access. When you modify EVERYONE permissions, you also modify the SYSTEM permissions, without knowing it. See “MORE INFORMATION” in the following MS KB article:
Excerpt:
“By default, the Everyone group has Full Control permissions on an NTFS volume. This permission might have been removed to provide additional security. Individual accounts, such as the Administrator account, may have been added. However, the Everyone group includes the System account. Removing the Everyone group without adding the System account as an individual account renders the paging file unusable.”
Naji Shaman
Reply to 1st answer:
Hi Naji,
thanks for your hint. I’ve verified the permissions and SYSTEM user has Full Control to C:\ and C:\WINNT.
I haven’t modified any permissions nor deleted or moved any group. May be this is the problem?
Greetings
Rolf
2nd answer:
Try allowing write access for the User to the folder
c:\winnt\system32\ias
This corrected my problem I had.
Tim
3rd answer:
Hi Rolf
We have had the same problem and the following helped:
Overwriting the existing odbc.dll file in your windows folder with a newer one (as far as I can see it is not the same odbc.dll I have that you have tried ).
You can mail me if you want the file
Mads Morre
Reply to 2nd answer:
Hi Tim,
this was the solution to my problem, too.
Thanks much
Rolf
Thanks a lot for the help
On my terminal server I only had to give ”Remote Desktop Users” ”Full Control” on folder %systemroot%\system32\ias to make the ODBC driver work.
Why or what the ODBC driver use IAS folder to don’t ask me [:O]
I 'am just happy it’s working [:D]
br
Jesper
Maybe you may now mark the thread as Solved?
Hi Jesper,
navision.net was stopped a few years back now, and moved to www.mbsonline.org , so your link is at
just replace navision.net with mbsonline.org
by the way, where did you find that link? It seems quite old.
