Navision Developer's Toolkit and SQL Server
Hi all, I’m trying to use navision developer’s toolkit on an SQL Database. I created the DB with Navision 4.00, I’ve imported the objects, created the company and then I tried to open the DB with NDT. I get this error: “The ? collation is not supported by Microsoft Business Solution Navision” Error 52016 After this, is impossible to open the DB also with Navision client. I created another DB using the SQL collation and not the Windows one, but I got the same error. I cannot understand if it’s a problem of configuration or is a problem related with NDT. Thanks Marco
Solved. [:D] The problem was the flag Auto Close that was checked. I found in a post that the same error was in 3.70…[B)] Bye marco
