Hi ! I would like to know if Navision Axapta can be run on Linux Server! Thanx
Hi Short answer: no. (Except maybe some emulators). The only thing which could run on Linux would be an Oracle DB Backend. And that would even be a good choice.
Hi, The Axapta client does not run on Linux. But my .02 cents - Alternatively you can create a web application integrating with Oracle sitting on Linux server. If you go down this line, then you might find it easier if you use XML integration tool such as EntireX. Regards, Harish Mohanbabu
