Navision 5.00 licence file (FLF)
I use a developper license (working with 4.00) but when I want to create a new company using version 5.00 W1, I get the message “You do not have the permission to run Application launch management codeunit”
Do we have to get a new licence file to use 5.00 ?
Thanks for your help
Jean
Yes unfortunately you do, I’ve tried using developer licenses in Nav 5.0 and I’ve had some strange errors.
Had the same problem with Menu Suites when 4.00 cam out.
The new license will have a XX-XX-005 in the serial number, 4 licenses have, funnily enough, 004
/TH
Even I got the same error message while doing the same, I believe you will require a NAV 5.0 developer liscence to do the same. The 4.0 liscence does however opens some of the Forms, reports and tables, but it doesnot allows to open the Codeunit Application Launch.
Thanks I will contact MBS [8-|]
