Hi, we have navision 3.70 with its own database running. I want a backup solution where my navision database is mirrored for example every 30 minutes (or minor) to a second navision server. Also when navision server1 crashes I want easily switch to server2 and my navision users could work again. Which hardware or software need I therefore? thanks!
Hi, Take a look at the Navision Hotcopy. It is a commandline program, included with the Navision Server.
This is an area where the MS SQL database is a superior database choice. You could have a full backup run every 30 minutes and transactional backups every two minutes if you wanted. Django
