Hi, does anybody have experience with Navision 2016 on teminal server ?
Why is NAV 2016 (RTC) client much slower then older version NAV 2009 ?
Local installed client on PC is faster for 50% in compare to terminal remote App.
Thanks a lot
V.K.
Thanks a lot
V.K.
Hi VK,
If you want the advantages of RDP, then consider using the ClickOnce installer.
The new windows client is slower and needs more ressources because this client is much complexer and has much more opportunities in layouting and configuration. in most cases a hardware ugrade is needed to get a good performance. the old client was fast because it was a very simple tech. and layout.
Hi VK, Please could you give me some details on your case? I have exactly the same symptoms, and if you will share your findings, or perform the steps to troubleshoot the problem, it would help me in my case. The solution was to strengthen the infrastructure or hardware to software optimization levels. I’ll be glad for any advice. Thank you very much in advance.
VK, it depends on other certain things too.
My case in lite summary, NAV2016 client (RTC) is very slowly, but 2009 is OK.
Which way is the right solution, who knows?
T.
Hi ,
there is a lot of things you have to do to improve NAV performance. First optimize DB. Check/define Maintanance Plan for update statistics, rebuild indexes, but I think, that main problem is in poor written code (codeunits). Its big challenge for NAV admin/developer. It was our case.
Are you from Czech republic ? If yes, i can recommend dev. company.
Bye
Yes, I am from CZ, if I could have a specifying question in Czech, please contact me on tomik.hp@sez…
Thanks a lot
