Hi All
Hope this finds you well.
I need to carry out some application performance test on 2009 Nav classic. The application start up speed is extremely slow , taking up to 25 seconds and often freezes
Could you please point me where to start, what i need to check/modify?
Ram is 32 GB on server 2012
Hi Douglas
I would personally start by recompiling all objects. Then I would restart the server, then the instance … but you probably have than all this already.
I would then launch SQL Server Profiler and check what is querying the database. Or I would google for a query to capture running transactions.
After you figured out what the problem is and your system is behaving normally I would build a server baseline. Check my article here:
http://wp.me/p6WwU9-5Z
Good luck!
Hi Silviu,
Thank you for the response. i have gone through your document and will need to research more on using the methods mentioned.
Much appreciated,
Douglas
