Hi Joeri I’ve do it, and it seems to work fine, but there is quite a lot of setup to the new Outlook Sync, so its going to be hard to find where your issue is if I can’t see it.
If you just Synchronise and don’t do a full sync does it give you the update about whats happened? i.e. 1 record modified etc?
