I have a card-page which contains among others a sub-page. I need to filter this sub-page via a RecordID filter being able to filter by code as a record ID can’t be linked via a SubPageLink Property.
All this works properly in the RTC client. But I need to publish the page as Web Service and unfortunately under these conditions the RecordID filter doesn’t work.
As a result I receive all data-sets in the sub-page hence the filter has been ignored.
If I debug the Web-Service, the code is run correctly, but then the result is wrong.
Does anybody can give me an advise about what to do? Actually this should work with Web Services, shouldn’t it?
RecordID is a very special field. It’s 250 characters long, but when you export it, then you only get the same “representation” as if you just put it into a page. You just get a text with the table name and primary key.
You could create a function which would return the value in a more useful fashion.
