Hello,
I am trying to upgrade Nav 3.70 to 5.00
I have created NAV 5.00 customized version and regarding table and data as per upgrade toolkit i have moved to Navision 5.00 and I have followed the steps Data conversion (Upgrade 5.00 Step 1) Now the probem is the G/L account table does not contain ‘GIFI code’ field but the customized object created using developers toolkit contains source expression as ‘Gifi code’ and so if I manually trying to create the field means it am getting permission problem.
Because this is a developer license and also i cannot export it to base version and then i cannot do modification, if i do that, I will loose the data.
Please help me in this.
