NAV updates
Hi Nav Devolopers,
I am using visual studio code for navision in browsers they are showing nav build version (10.0.14540) but this version i am not abble to find these vesion can you any one send this version download link …
please share the link
Thanks & regards,
Divakar Reddy
Hello,
go thru below link:
Microsoft Dynamics NAV ‘Tenerife’ Developer Preview
Hi singh,
In that link only they are saying nav version 10.0.14540 but i am not getting that setup …so i installed for more update version (10.0.15601) but in that one also in Administration server the devolopment option is not getting … please see the above screenshot …i want that last mode in my navision
thanks & Regards.
NAV version 10.0.14540 and .15601 are just very early builds. Visual Studio Code requires the Dynamics NAV “TENERIFE”, like:
But you cannot download it as such. You can try it out by setting up an Azure VM by following this link for the September version of the Developer Preview.
But once you have setup your Azure VM, then what Ashwini Tripathi suggests is that you then copy the NAV files on the Azure VM down to your local PC (or local VM). It’s a rather technical process do do it. But it will save you the running costs of the Azure VM (remember to shut it down when you are down, otherwise it continues to run up costs).
