We are planning to update our NAV 5.0 SP1 System to NAV 2013 R2.
As I know, I have to do an update to 2009 SP1 first.
The converting of the database works. But when I want to run the 104001 Upgrade - Old Version (I imported 601700.1.fob, not 601701.1.fob → I don’t have this file in my UpgradeToolKit, where can I find it?), I got the following error (in any company):
“Reference to the member Abbreviated Name of the variable could not be solved.”
I read that the Abbreviated Name is a new field in 2009. Where can I get it?
And what is this error message and how can I fix it?
If specified file not found in your toolkit then you might need to download the installed for NAV 2009 SP1 again and check from the upgrade toolkit again
@Anil Kumar Anisetty: ah, I will try it with R2 again. But I think the UpgradeToolKit is in the 2013 package, because 2009 has only 400 and 370.
@Amol: Where can I find this information?
I know this tutorial and it is nice, the only problem I have: I don’t know how to do the “compare and merge process”. Do you have a detailed tutorial or manual for it?
