Hi everybody,
Do you have any idea of getting NAV standard reports in excel?
Hi everybody,
If it is NAV2009 or higher, then in RTC you can save the report as Excel and PDF.
For earlier version you can use File → Save as HTML and then open in Excel. The format (depends on the report) is not great but it works. For nicer exports to Excel it requires coding - look in the standard Aged Accounts Receivable for an example.
