I work for a company that designs, manufactures, markets and retails its products (direct to consumer and via other channels).
We have chosen Navision to replace over 5 ageing disparate systems and are in the design phase of the project.
One part of this process is to specify the hardware/software infrastructure to support the system in line with performance and availability expectations.
We will shortly receive proposals for the Navision servers (hardware & software including OS and SQL 2005) from two potential infrastructure suppliers.
I’m keen to undertake as much research as possible to assist in the supplier selection process. Any tips, advice or links regarding Navision performance and what areas the suppliers should be focusing on will be greatly appreciated.
Aside from the performance requirements of the system high availability is also key. I would like to remove the Navision SQL servers and associated storage as a single point of failure through the use of clustering, SQL mirroring or other similar technology and any comments or experiences in this area would be appreciated.
Our Navision system will be used by the whole business and be interfaced with the following systems;
- Preactor for production scheduling/resource planning purposes
- Microsoft RMS - current Epos system
- Microsoft BizTalk - Current B2C website
We will have 140 concurrent users from go live with 15% increase per annum (all will be on one site)
80% of the users are order entry operators entering on average a total of 6000 orders per day (average of 1.4 items per order) with the same number of warehouse shipments
We will be performing marketing database segmentation creation and management within Navision
Over 2,000000 customer records and 1,000000 contacts will be imported into Navision prior to go live
I can provide further detailed information if required.
Regards
Adam
