I have installed NAS on my machine and done all the setups.I have setup in Jobs entry card to Run a Particular Report at Specific time.My query is Will this report would run if Navision is closed on my computer at that time when Report has to run?
Thank you
It will be excecuted even client is not open in your system…
Hi thnkx for the Reply but for me it runs sometimes only when Navision Client is running. for example i have set it to run daily and i have created one more job scheduler to run it but some how it is not running but it runs when i manually run the Codeunit(Job disptacher).DO you have idea what may be the problem
Which version are you using?
then no need to open the client…
I guess Job scheduler means Job Queue entry,right?
Is your service running successfully? check the eventviever after running the service…
yes i mean Job Queue Entry and how to check in event viewer there are so many applications which one to check exactly
Just stop your NAS Service and Start…
You will have an Application Log with Application Server…
