NAV 5.0 Keyboard Shortcuts
Hi all I want to know the keyboard shortcuts for MS dynamics NAV 5.0 … whr i can get it
Mostly used.
In design mode:
Shift+F4 = Properties
F9 = C/AL Editor
F5 = Symbol Menu
F3 = New
In running forms:
Ctrl+F8 = Zoom
that are what i frequently use
Go to Help Menu - Overview of F keys… this will give functions keys available for that part of application…
you can read about this from Help - microsoft dynamics nav help - using dynamics nav
other than above, normal windows shortcut like cut, copy, past will also work in attain.
Don’t forget to the post(s) that solved your problem. This credits the experts who helped, earns you points and marks your thread as Resolved so we all know you have been helped.
Following are the main short-cut keys:
F1 = Help
F2 = Edit
F3 = New Record / Lines
F4 = Delete
F5 = List
F6 = Lookup / Drill down
F7 = Field / Column Filter
F8 = Copy Previous
F9 = Statistics
F11 = Post
F12 = Start / Menu
Ctrl + C = Copy
Ctrl + X = Cut
Ctrl + V = Paste
Ctrl + F = Open Find Box
Ctrl + P = Print
Ctrl + Z = Undo
Ctrl + F2 = Designer
Ctrl + F4 = Close
Ctrl + F5 = Ledger Entries
cTRL + F6 = Next Window
Ctrl + F7 = Table Filter
ctrl + F8 = Zoom
Ctrl + F11 = Release Document
Shift + F5 = Card
Shift + F7 = Flow Filter
Shift + F8 = Sort
Shift + F11 = Post & Print
Shift + F12 = Object Designer
Addition : Use Ctrl 1 , Ctrl 2 … to Ctrr9 to navigate within the menu in this sequence.
  1. Fin
  2. Sales
  3. Purch
  4. Ware
  5. Mfg
  6. Jobs …
