I upgraded a Customer NAV database from 2013R2 to 2018CU5, after some operation for include the app extension management, I connected VS Code to the upgraded Customer NAV2018, and I dowloaded the Symbols.
I wrote an application in AL Code and I published and installed it, on a standard Cronus database NAV2018CU5 on the same server.
I tried to make the same on the customer nav2018 database, but doesn’t work. So, I have a PROBLEM with to publish the app.
In details, the VS Code return this Error: “dev/apps?tenant=default&SchemaUpdateMode=synchronize failed with code InternalServerError. Reason: Cannot install apps due to the state of the tenant: OperationalDataUpgradePending.”
After I opened the WebClient of customer, and from Extension Management I saw the estention published but I cannot Install because the webclient return this error:
“A call to Microsoft.Dynamics.Nav.Runtime.Apps.NavAppALInstaller.ALInstallNavApp failed with this message: Cannot install apps due to the state of the tenant: OperationalDataUpgradePending.”
I opened the PowerSheel ISE and I compared the configuration of the tenant:
ServerInstance : MicrosoftDynamicsNavServer$CUSTOMER2018
DatabaseName : CUSTOMER2018
DatabaseServer : NAV2018
DatabaseUserName :
State : OperationalDataUpgradePending
DetailedState :
DeletionState : Not deleted
IsInExclusiveAccessMode : False
TenantDataVersion : Uninitialized
AlternateId : {}
AllowAppDatabaseWrite : True
NasServicesEnabled : False
RunNasWithAdminRights : False
EncryptionProvider : LocalKeyFile
AzureKeyVaultSettings :
DefaultCompany :
DefaultTimeZone : UTC
ExchangeAuthenticationMetadataLocation : https://outlook.office365.com/
AadTenantId : common
DisplayName :
UrlName :
EnvironmentType : Production
ServerInstance : MicrosoftDynamicsNavServer$DynamicsNAV110
DatabaseName : Demo Database NAV (11-0)
DatabaseUserName :
State : Operational
DetailedState :
TenantDataVersion : 11.0.21836.0
AlternateId : {}
DefaultCompany :
DisplayName :
UrlName :
Have u some suggestion?
Thank you,
Roberto.
