I have the Job Queue setup and tested manually. But I’m needing is to run Object ID 14031460 Commissions Due Detail per Sales Person Code ex: 26 and Posting Date: -4d…t. Is this possible via entering this somehow into the Parameter String?
Hi Bkr2016a,
What is:
It’s not a standard NAV object, so you should check the documentation or contact whoever developed it. Any parameters needs to be developed into any report/codeunit you run via job queue. If the object is not specifically developed to run with the job queue, then it often isn’t possible. In that case you would need a developer, to program a job queue handler (a new codeunit) to run the other object. Some codeunits for example may need to be rewritten to work.
