Hi Forums Team members,
We have a situation, where we are trying to use Azure VM as our NAV Server and SQL Database Server and when we trying to save changes in the Table. We get the following error.
Please find below further more environment details for your information.
- NAV Server and SQL Server is hosted on AZURE VM
- NAV Development Environment and client works fine, when connect Azure VM through RDC.
- NAV Client can be connected to NAV Service from outside Azure VM with NAVUserPassword credential type
- NAV environment is having single database multiple companies in is having single Tenant.
- When the Development Environment of NAV 2016 cumulative update 9 or NAV 2017 Cumulative update 1 is opened in Azure VM, we can compile and save tables.
- But when we open Development Environment of NAV 2016 cumulative update 9 or NAV 2017 cumulative update 1 in developer Laptop, and try to make changes or add new fields in the tables we get above error.
We have already tried following things to resolve the above issue, but the issue is not resolved.
- Turned off Windows Firewall on both Azure VM and developer laptop (Windows 10 Enterprise Edition)
- Management service is also configured in NAV service and endpoint is also configured on Azure cloud
- Configured in development environment in Tools → Options, entered server port, service name and management port.
But still not outcome.
Do any one have configured similar type of environment and it is working fine.
