NAV 2015 RTC do not save last opened DB
Hello,
I want to open DB through my shortcut. I’ve made such settings in it:
“C:\Program Files (x86)\Microsoft Dynamics NAV\90\RoleTailored Client\Microsoft.Dynamics.Nav.Client.exe” “DynamicsNAV://SERVER:9246/AAAA2015/Demo/”
Everything is good, it open DB and I can work. But if I’ll change in RTC to another server it RTC and try to open my shortcut again - I’ll have a message
‘You’re about to connect to AAAA2015 on server SERVER which is not your current default connection string …’
Is there any way to get rid of this message?
I can see, that my ClientUserSettings.config is cahnged every time I change my DB in RTC. I want always open my DB from shortcut settings without any questions.
If I try to run shortcut with my custom config (I’ve copied it and made changing) - I got an error when I’ve change DB and try to close RTC.
Thank you
I’ve found the solution - making several .config files, placing them in shortcut’s -settings:“C:\Config1.config”. I just put my first config files in wrong place (write-protected).
thx for the info.
