One of the great things in NAV 2013 R2, compared to NAV 2009, is that you are able to use the debugger. In NAV 2009 RTC it was a huge problem, if your pages or reports didn’t work the way they were supposed to.
But I’m still having a problem in NAV 2013 R2 with the debugger. Whereas the debugger works just fine, then I have noticed that if I’m debugging the request page, then I’m not able to see the variables. Neither by opening the Variable page, nor by holding the mouse over the variable in the code.
I’ve not seen any reports about this issue, so I like to know if I’m the only one where this does work?
