RIGHT ARROW
RIGHT ARROW
Move to the next field or character
LEFT ARROW
LEFT ARROW
Move to the previous field or character
UP ARROW
UP ARROW
Move to the field above in the same column
DOWN ARROW
DOWN ARROW
Move to the field below in the same column
DELETE
DELETE
Clear selected text
ESC
ESC
Close the window or undo the data entry
END
END
Move to the last field on a line
HOME
HOME
Move to the first field on a line
TAB
ARROW, TAB, ENTER
Move to the next field on non-line FastTabs
ENTER
Move to the next editable field
F1
F1
Open Help
F2
F2
Edit
F3
F7
Select Type to filter (field filter)
F4
F6
Drop down or look up to select
F5
Refresh the active window
F6
CTRL+PAGE DOWN
Go to the next frame
F7
F9
Display statistics
F8
F8
Copy the field above
F9
F11
Post
F10, ALT
F10, ALT
Select the menu bar and display access keys
F12
F12
Select the navigation pane
SHIFT+F1
View error message
SHIFT+F3
CTRL+F7
Select Show Results (FlowFilter)
SHIFT+F4
F6
Open a lookup window (from an ellipsis button)
SHIFT+F6
CTRL+PAGE UP
Go to the previous frame
SHIFT+F7
CTRL+F5
Open the related card
SHIFT+F8
F6
Drop down or look up to view
SHIFT+F9
SHIFT+F11
Post and Print
SHIFT+F10
SHIFT+F10
Display a shortcut menu
SHIFT+F11
SHIFT+F11
Apply Entries, Get Source Doc, or Get Whse. Doc
SHIFT+F12
Open the Role Center from the navigation pane
SHIFT+Tab
ARROW, SHIFT+TAB
CTRL+F1
Collapse or expand the Action Pane
CTRL+F2
F3
Create a new document
CTRL+F3
Select Search pages
CTRL+F4
F5
Look up to the related list
CTRL+F7
CTRL+F5
View entries
CTRL+F9
CTRL+F11
Release document
CTRL+F10
Select the Action Pane and display key tips
CTRL+F11
CTRL+F11
Reconcile or Split Line
CTRL+F12
Select the address bar
CTRL+C
CTRL+C
Copy
CTRL+E
CTRL+E
Export to Microsoft Office Excel
CTRL+L
Show Links
CTRL+N
F3
Create a new record
CTRL+O
CTRL+O, F12
Open the company
CTRL+P
CTRL+P
Print
CTRL+T
SHIFT+F8
Select Sorting
CTRL+V
CTRL+V
Paste
CTRL+W
CTRL+W
Export to Microsoft Office Word
CTRL+X
CTRL+X
Cut
CTRL+Z
CTRL+Z
Undo
CTRL+PAGE DOWN
PAGE DOWN
Display next document or card in a list
CTRL+PAGE UP
PAGE UP
Display previous document or card in a list
CTRL+UP ARROW
Move up while the selected line stays selected
CTRL+DOWN ARROW
Move down while the selected line stays selected
CTRL+LEFT ARROW
CTRL+LEFT ARROW
CTRL+RIGHT ARROW
CTRL+ALT+F1
CTRL+F8
Open the About this Page/Report window (Zoom)
CTRL+DELETE
F4
Delete the selected line
CTRL+HOME
CTRL+HOME
Move to the first line in a list
CTRL+END
CTRL+END
Move to the last line in a list
CTRL+ENTER
ESC
Save and close window (equivalent to clicking OK).
CTRL+INSERT
F3
Insert new line
CTRL+SHIFT+F3
SHIFT+F7
Select Limit totals to (table filter)
CTRL+SHIFT+A
CTRL+SHIFT+F7
Clear all filters
CTRL+SHIFT+C
F3
Open a new card
CTRL+SHIFT+D
CTRL+SHIFT+D
Show dimensions
CTRL+SHIFT+K
Edit list
CTRL+SHIFT+L
View list
CTRL+SHIFT+Q
CTRL+SHIFT+A
Collapse/expand a line in a hierarchy
CTRL+SHIFT+V
Open a card or a document in View mode
CTRL+SHIFT+W
CTRL+ENTER
Open a list place in a separate window
CTRL+SHIFT+ENTER
Save and close the window and open a new window
ALT, F10
ALT, F10
ALT+F3
F7
Filter to the value in the field
ALT+F4
ALT+F4
Close window or close program
ALT+F6
Collapse or expand the active frame
ALT+F10
Display the Actions menu of the active frame
ALT+A
ALT+I
Display the Related Information menu
ALT+R
Display the Reports menu
ALT+M
Display the Microsoft Dynamics NAV menu
ALT+LEFT ARROW
Go to the previous window in the navigation history
ALT+RIGHT ARROW
Go to the next window in the navigation history
ALT+ENTER
Move to the field below without opening the drop-down menu
ALT+TAB
Switch among open windows
