Hi All.
I am a newbie here and also a newbie to Dynamics. We have setup a test company using Nav 2009 R2 Classic w/ SQL Option. I understand that most configuration and setup needs to be done there, however not that the company is setup, we can connect through Role Tailored Client. When I open RTC it seems to always connect to the default Cronus native database. When I go to select server, it does not give me an option to connect to a SQL Server.
I went to run > services.msc and setup the connection of using a domain account that we use in classic to connect. All logins are synced. What do I need to do in order to connect RTC to SQL. Is there a procedure somewhere to follow?
Much thanks. Looking forward to collobrating.
Jared
