I have done the following:
This is for retrieve a range of record by the month and year selected by user. For example, if user select month: 9 and Year:2014, then result will will be 1/9/2014 to 30/9/2014. Besides the record within this data range, the very first record in the database table will also displayed in the report.
DateOfFirstDay := DATE2DMY(CALCDATE(’<-CM>’,DMY2DATE(1, month + 1, year)), 1);
NoOfDaysInMonth := DATE2DMY(CALCDATE(‘CM’,DMY2DATE(1,month + 1,year)),1);
StartPayDate := DMY2DATE(DateOfFirstDay, month + 1, year);
EndPayDate := DMY2DATE(NoOfDaysInMonth,month + 1, year);
SETRANGE(“Pay Date”, StartPayDate, EndPayDate);
May I know what is the problem, anyone have idea ? Please advise. Thanks in advance.
hi
why do you calc the first of month? it’s always the 1st.
in your case, if a user selects 9 as month, you calc. with 10, also with October.
i tested your code with a report and using table sales header as dataitem (in nav 2009 r2).
in the “Sales Header” - OnPreDataItem Trigger i wrote:
month := 1;
year := 2011;
firstDayOfMonth := DATE2DMY(CALCDATE(’<-CM>’,DMY2DATE(1, month + 1, year)), 1); // always 1
noOfDaysInMonth := DATE2DMY(CALCDATE(‘CM’,DMY2DATE(1,month + 1,year)),1);
startDate := DMY2DATE(firstDayOfMonth, month + 1, year); // giving the 1st of next month
endDate := DMY2DATE(noOfDaysInMonth,month + 1, year);
“Sales Header”.SETRANGE(“Posting Date”, startDate, endDate);
ran the report, everthing works fine. result is ok.
Jonathan,
Thanks for your help!! Just realise I put the code under OnAfterGetRecord() function.
Now everything work perfectly!!
Thank you so much.
Jonathan,
Thanks for your help!! Just realise I put the code under OnAfterGetRecord() trigger.
Thank you so much.
admin1
November 21, 2014, 6:33am
5
Looks good and does the job, but why all that code??
This will do the same.
StartDate := DMY2DATE(1,Month,Year);
SETRANGE(PayDate,StartDate,CALCDATE('<CM>',StartDate));
