Check if your Dev license contains version 2009 (6?) or Future versions granules.
According to message you get, it’s not included - you need an updated license file.
How to open the License file?with Notepad it is appearing only company name and address,and other details are in unsupported format,which are unable to read.Can you please suggest.\
I created a new database through finsql.exe,and created a company on it,while we are opening that new company,we are unable to get the menu tables like "“general ledger,cassh management, in the left pane”
Begining of .flf file is in human-readable format, there you should look for Granules available.
Other part is encrypted license itself. There should be a supplemental .txt file, which has more info in it, but even in .flf there is
XXXX Navision version x.xx
which you CAN see in Notepad. If Ver2009 isnt there - you need to update the .flf file from MS
You need to Restore a backup file. Backup file have (.fbk) extension, go to your newly created database, Tools>> Restore and then locate the backup file (Search for *.fbk in your NAV2009 downloaded folder) and then restore.
I think you can check the contents of your license file, even before doing all these activities.
Dan, not always true - I was able to do it some time ago, don’t know if this possibility is still there in PS… It was in Partner’s parameter part, together with pending Support requests & oustanding Invoices…
We dont have any old NAV,we are now newly implimenting NAV 2009 in our office.i installed NAV 2009 with developer options,and after installing that i got a demo database,with demo database also,i tryed to upload the license file,and i got the same error.So,please suggest me?
hi,ok,please tell me some tips to Install and configure the NAV 2009 with developer options in two mechines First one is SQL,FINSQL.exe,in second mechine is to be RTC.
