I’m trying to (RE) install Nav 2009 into my PC where MS SQL Server 2008 is already installed. Can anyone give me the details of the Installation Process…?
At first I want to install Nav database server or Nav SQL server with the Classic Client and then try with it to ensure is it working or not in PC
MY PC Name is ADEY, IP Address is 192.168.0.158. PC is running on Windows XP SP3 Operating System.
I have attached some screen shots where I have to put some parameters but I can’t understand what parameters I have to define….
In Nav 5.0 Installation, I have to select the database and license file.But In Nav 2009 where I have to select/specify these two ?? I don’t want RTC now. I just want to connect my DB via Database Server Option.
Now I’m trying to install nav 2009 Demo version in my pc ( Windows xp sp3 ) where Configuration Tools of Microsoft SQL Server 2005 is pre-installed. After Installation complete it gives me an error message. …
Microsoft Dynamics NAV 2009 Build 27808
Error Report
SQL Server option
Cronus Sample Database for Microsoft Dynamics NAV 2009
Fatal error during installation.
Error -2147467259: failed to execute SQL string, error detail: A database with name Demo Database NAV (6-0) already exists., SQL key: StopIfDatabaseExist SQL string: IF EXISTS (SELECT * FROM [master].[sys].[databases] WHERE name = ‘Demo Database NAV (6-0)’) RAISERROR (N’A database with name %s already exists.’,20,1,‘Demo Database NAV (6-0)’) WITH LOG
Created on “PC”
3/6/2009 1:12 PM
After Complete Installation nav 2009 how can I connect my Demo Database Nav (6-0) via MS Dynamic Nav 2009 Classic with Microsoft SQL server ??
When I try to connect vai RTC it gives me an error message Ther user ID and password is invalid. Try again .
The difference between server and database server is that server refers to Microsoft Outlook where as Database Server is the usual “propriatory” database server of NAV.
