Hello,
On one worstation we obtain the following error message when we try to export from Excel (export from analysis view to Excel pivot or Print to Excel checkbox). The action->Send to->Microsoft Excel works fine.
We use NAV 2009sp1 and Excel 2010.
Has anybody got an idea ?
Thanks in advance for your help and best regards
SG
The server “net.tcp://localhost:7046/DynamicsNAV/Service” is either unavailable or your connection has been lost. Do you want to attempt to reconnect?
Event Log :
Type: Microsoft.Dynamics.Nav.Client.NavClientClosingException
Message: La connexion au serveur a été perdue. L’application va fermer.
StackTrace:
at Microsoft.Dynamics.Nav.Client.ExceptionHandler.DoExecute(Func1 execute) at Microsoft.Dynamics.Nav.Client.ExceptionHandler.DoRethrowWithCatchException(Exception exception) at Microsoft.Dynamics.Nav.Client.ExceptionHandler.Application_ThreadException(Object sender, ThreadExceptionEventArgs e) at System.Windows.Forms.Application.ThreadContext.OnThreadException(Exception t) at System.Windows.Forms.Control.WndProcException(Exception e) at System.Windows.Forms.Control.ControlNativeWindow.OnThreadException(Exception e) at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam) at System.Windows.Forms.UnsafeNativeMethods.DispatchMessageW(MSG& msg) at System.Windows.Forms.Application.ComponentManager.System.Windows.Forms.UnsafeNativeMethods.IMsoComponentManager.FPushMessageLoop(Int32 dwComponentID, Int32 reason, Int32 pvLoopData) at System.Windows.Forms.Application.ThreadContext.RunMessageLoopInner(Int32 reason, ApplicationContext context) at System.Windows.Forms.Application.ThreadContext.RunMessageLoop(Int32 reason, ApplicationContext context) at System.Windows.Forms.Application.Run(ApplicationContext context) at Microsoft.Dynamics.Nav.Client.WinClient.RunCore() at Microsoft.Dynamics.Nav.Client.ExceptionHandler.ExecuteAndCatchExceptions(Func
1 execute)
at Microsoft.Dynamics.Nav.Client.ExceptionHandler.DoExecute(Func`1 execute)
at Microsoft.Dynamics.Nav.Client.WinClient.Run()
Source: Microsoft.Dynamics.Nav.Client
Type: Microsoft.Dynamics.Nav.Types.NavConnectionLostException
StackTrace:
at Microsoft.Dynamics.Nav.Client.ExceptionHandler.<>c__DisplayClass2.b__0()
at Microsoft.Dynamics.Nav.Client.ExceptionHandler.ExecuteAndCatchExceptions(Func`1 execute)
StackTrace:
at Microsoft.Dynamics.Nav.Client.ConnectionStateManager.HandleCommunicationFailure[T](CallServerMethod1 callServerMethod, Exception e, Int32 messageNumber, String sessionId) at Microsoft.Dynamics.Nav.Client.ConnectionStateManager.CallServer[T](CallServerMethod
1 callServerMethod)
at Microsoft.Dynamics.Nav.Client.ServerInvocationHandler.CallServer[T](CallServerMethod1 callServerMethod) at Microsoft.Dynamics.Nav.Client.ServiceConnectionBase.CallServer[T](CallServerMethod
1 callServerMethod)
at Microsoft.Dynamics.Nav.Client.ServiceConnection.RunReport(Int32 reportId, Boolean suppressRequestForm, NavRecordState& state, NavDataSet recordDataSet, IList`1 textualFilters)
at Microsoft.Dynamics.Nav.Client.ServiceConnection.RunReport(Int32 reportId)
at Microsoft.Dynamics.Nav.Client.Actions.RunReportAction.InvokeCore(Boolean async, LogicalControl logicalControl, Object state, UISession uiSession)
at Microsoft.Dynamics.Framework.UI.Action.InvokeCoreWithErrorHandling(Boolean async, LogicalControl logicalControl, Object state, UISession uiSession)
at Microsoft.Dynamics.Framework.UI.Action.DoInvoke(LogicalControl logicalControl, UISession uiSession)
at Microsoft.Dynamics.Framework.UI.ActionControl.Invoke()
at Microsoft.Dynamics.Framework.UI.Windows.ActionControlAdapterBase.DefaultInvokeAction(LogicalControlAdapter adapter, ActionControl actionControl)
at Microsoft.Dynamics.Framework.UI.Windows.ActionControlAdapterBase.DefaultInvokeAction(LogicalControlAdapter adapter)
at Microsoft.Dynamics.Framework.UI.Windows.ActionControlAdapterBase.OnInvoke()
at Microsoft.Dynamics.Framework.UI.WinForms.MenuBarActionControlAdapter.b__0(Object sender, EventArgs e)
at System.Windows.Forms.ToolStripItem.RaiseEvent(Object key, EventArgs e)
at System.Windows.Forms.ToolStripMenuItem.OnClick(EventArgs e)
at System.Windows.Forms.ToolStripItem.HandleClick(EventArgs e)
at System.Windows.Forms.ToolStripItem.HandleMouseUp(MouseEventArgs e)
at System.Windows.Forms.ToolStripItem.FireEventInteractive(EventArgs e, ToolStripItemEventType met)
at System.Windows.Forms.ToolStripItem.FireEvent(EventArgs e, ToolStripItemEventType met)
at System.Windows.Forms.ToolStrip.OnMouseUp(MouseEventArgs mea)
at System.Windows.Forms.ToolStripDropDown.OnMouseUp(MouseEventArgs mea)
at System.Windows.Forms.Control.WmMouseUp(Message& m, MouseButtons button, Int32 clicks)
at System.Windows.Forms.Control.WndProc(Message& m)
at System.Windows.Forms.ScrollableControl.WndProc(Message& m)
at System.Windows.Forms.ToolStrip.WndProc(Message& m)
at System.Windows.Forms.ToolStripDropDown.WndProc(Message& m)
at System.Windows.Forms.Control.ControlNativeWindow.OnMessage(Message& m)
at System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m)
Source: Microsoft.Dynamics.Nav.Client.ServiceConnection
Type: System.ServiceModel.FaultException
Action: http://schemas.microsoft.com/net/2005/12/windowscommunicationfoundation/dispatcher/fault
Message: The server was unable to process the request due to an internal error. For more information about the error, either turn on IncludeExceptionDetailInFaults (either from ServiceBehaviorAttribute or from the configuration behavior) on the server in order to send the exception information back to the client, or turn on tracing as per the Microsoft .NET Framework 3.0 SDK documentation and inspect the server trace logs.
StackTrace:
Server stack trace:
at System.ServiceModel.Channels.ServiceChannel.ThrowIfFaultUnderstood(Message reply, MessageFault fault, String action, MessageVersion version, FaultConverter faultConverter)
at System.ServiceModel.Channels.ServiceChannel.HandleReply(ProxyOperationRuntime operation, ProxyRpc& rpc)
at System.ServiceModel.Channels.ServiceChannel.Call(String action, Boolean oneway, ProxyOperationRuntime operation, Object[] ins, Object[] outs, TimeSpan timeout)
at System.ServiceModel.Channels.ServiceChannel.Call(String action, Boolean oneway, ProxyOperationRuntime operation, Object[] ins, Object[] outs)
at System.ServiceModel.Channels.ServiceChannelProxy.InvokeService(IMethodCallMessage methodCall, ProxyOperationRuntime operation)
at System.ServiceModel.Channels.ServiceChannelProxy.Invoke(IMessage message)
Exception rethrown at [0]:
at System.Runtime.Remoting.Proxies.RealProxy.HandleReturnMessage(IMessage reqMsg, IMessage retMsg)
at System.Runtime.Remoting.Proxies.RealProxy.PrivateInvoke(MessageData& msgData, Int32 type)
at Microsoft.Dynamics.Nav.Types.INavService.RunReport(ApplicationMethodRequest applicationMethodRequest)
at Microsoft.Dynamics.Nav.Client.ServiceConnection.<>c__DisplayClass29.b__28()
at Microsoft.Dynamics.Nav.Client.ServerCallContext`1.InvokeCall(Object instance)
at System.Runtime.Remoting.Messaging.StackBuilderSink._PrivateProcessMessage(IntPtr md, Object[] args, Object server, Int32 methodPtr, Boolean fExecuteInContext, Object[]& outArgs)
at System.Runtime.Remoting.Messaging.StackBuilderSink.PrivateProcessMessage(RuntimeMethodHandle md, Object[] args, Object server, Int32 methodPtr, Boolean fExecuteInContext, Object[]& outArgs)
at System.Runtime.Remoting.Messaging.StackBuilderSink.AsyncProcessMessage(IMessage msg, IMessageSink replySink)
Exception rethrown at [1]:
at System.Runtime.Remoting.Proxies.RealProxy.EndInvokeHelper(Message reqMsg, Boolean bProxyCase)
at System.Runtime.Remoting.Proxies.RemotingProxy.Invoke(Object NotUsed, MessageData& msgData)
at System.Threading.WaitCallback.EndInvoke(IAsyncResult result)
at Microsoft.Dynamics.Nav.Client.ServerInvocationManager.CallServer[T](CallServerMethod1 callServerMethod) at Microsoft.Dynamics.Nav.Client.ServerInvocationHandler.CallServer[T](CallServerMethod
1 callServerMethod)
at Microsoft.Dynamics.Nav.Client.ConnectionStateManager.CallServer[T](CallServerMethod`1 callServerMethod)
Source: mscorlib
Pour plus d’informations, consultez le centre Aide et support à l’adresse http://go.microsoft.com/fwlink/events.asp.
