The Navision Application Server 3.10 seems unable to validate “Shortcut Dimension Code 2” field in the Salesline. It ends its code without any eventlog or whatsoever. As far as I know, NAS is not capable of using form-objectcode. I can’t find any form-objectcode when validating the “Shortcut Dimension Code 2”. My guess so far is, that the “Caption class”- code has something to do with it. Can anyone tell my if this is the case, and if there is a way to bypass any code that is causing this. Greetings
Simply create a new field in the salesline and fill in the dimension after validation. Also only solution for fysical flowfield calculations. Good Luck
I had already figured it out, but thanks anyway. Greetings,
