Not only do you need admin rights to install the service properly. The NAS service must be associated with an administrator account in order to function properly.
NAS also logs into navision using windows authentication so you need to setup a windows login with the necassary rights linked to an active user account, this active user account should also be the one that starts the NAS service (configured on the service properties page).
I either use the admin account or create a new user with admin priviledges.
It sounds like you might need to take it out and put it back in again.
What verson are you running SQL or Native?
To install from the command line, you must first move to the directory that the NAS is installed in, so if my NAS was in a folder called NAS, which was in a folder called Navision on the C:\ drive I would open command promt and type
Sorry if that seems like I’m teaching you to suck eggs, but experieance says I need to cover all bases.
Next you need the following information
What you want to call the application server (in the services) we will call this = MyAppServerName e.g AshishNAS
The name of the server you are connecting too = MyServerName e.g. AshishSQLServer
The name of the Database you are going to use (mainly in SQL) = MyDatabaseName e.g. AshishNavisionDatabase
The company you wish to use within that database = MyCompanyName e.g. AshishNavisionCompany
Lastly you need to know the startup parameter in Codeunit 1. (examples of standard ones are CG, MAILLOG, ADCS) = MyStartUpParameter e.g. EDI
Then we go back to the command line and type:-
Database is an optional parameter as it is mainly used with sql and in the above example i used the Sql version. for Native you would replace “NASSQL” with “NAS”
This is not correct. The NAS does not need an administrator account. it just needs the rights to accomplish its assigned task. Mainly the right to login as a service plus appropriate access to NAV.
