Hi, Does anyone know if there is an option so that it’s possible to export only changed objects (of a new merged version) instead of exporting all objects? [?] I’m using Navision Attain Developer Toolkit 1.02
If the new merged version include all objects you can only filter by e.g. version list. This goes for Export as well as Update to Navision Client. Before you merge you can limit the objects which are included in the merged version (result of merge) by specifing which version to “Focus on” during merge. In the merge setup look at the help for field “Focus on Objects in”.
Ahh. Thanks Jens Ole. I’m going to try that next time.
