I have activated multisite on my dev environment now i have to activate on other environment.so is there any way to deploy these multisite activation changes to other environment. or i have to run the activation wizard on another environment also.can anyone guide me on this. thanx in Advance.
Assuming this is AX2009? You need to run the same process as you did in your dev environment.
Thank You
